How many hours on your tractor.
sparky45
L 3301DT
Dec 5, 2018
248
51
SEDAN
Got my Kubota 10-1-2018 just did my 50 hour maintenance. Most major problem was removing the Hydraulic filter.
Magicman
Oct 8, 2019
5,098
6,540
Brookhaven, MS
knotholesawmill.com
I bought my "new to me" M4900 in September showing 1055 hours but of course I have no way of determining if that is actual. The tachometer cable broke a few weeks ago and when I replaced it, it was easy to see that the ends had not been disconnected in a number of years, so who knows, that might be the actual hours.
4,032
Been a while; I’m at 370 now for a’13 BX2360.
My use figures about an hour/week year round.
leveraddict
Apr 1, 2019
906
582
NEPA
October 2017 BX23S just turned 310 hours! What I did on my property would have cost more than the purchase price of the machine if I had hired landscapers!
4,032
You bet!
While my run-rate is an hour/week over 6+ years, it doesn't reflect the work it's done in time.
Guessing I've done about $6-8,000 worth of landscape grading and driveway work with the BX over the years I would have needed to hire out.
A 20 ton load of driveway stone only takes me 90 minutes now..and that includes a break or two for adult beverages..... practice makes perfect![emoji41]
Sent from my QTASUN1 using Tapatalk
2,234
I posted 1411hrs back on 1-26-18. I currently have 1441hrs. Sadly, that is only 30hrs in 22 months. :(
Mak65
L2501 HST
Apr 25, 2019
112
65
TX
I’ll play. Took receipt of a new L2501 on 4/12/19 and it has 40.1 hours on it as of this past Saturday. Coming up on the 50-hour maintenance time.
SidecarFlip
Banned
548
I don't remember if I ever replied to this thread (getting senile I guess)
M9000 HD (2002) 3700 hours
M9000 HDCC3 (2004) 1750 hours.
Kubota Sidekick (new) 33 hours
Lotta diesel.:)
Bmyers
May 27, 2019
3,173
3,663
Southern Illinois
Got my tractor Memorial day week of this year, 56 hours on the tractor. Waiting for my 3rd function valve to come in and tractor will go to the dealer and get the valve installed and the 50 hour service completed.
leveraddict
Apr 1, 2019
906
582
NEPA
You bet!
Yes sir! And after all that I still have a great machine that will serve my twisted carcass the rest of my days!:)
Ryansweatt2004
2017 kubota L3901HST
Jul 2, 2015
205
West gardiner maine, USA
2017 kubota L3901 hst turned over 650 hours recently. Only problem so far was the seat bracket broke at the hinge. Other than that it’s been an absolutely wonderful tractor.
NoBiffBetter
193
Silver Creek, NY. USA
Iv got a 2013 Kubota bx2370 purchased it with 400 hours about a year ago I now have 640 hours on it.. those 240hours I put on it were HARD worked hours.. I work this little machine way past it’s limits almost weekly.. she’s been holding up like a tank. It does need 2 new outter tie-rods both have become loose which is common, aside from that the bracket that holds the front steering cylinder is getting some play in it but the bracket is cheap/easy to replace. No other issues otherwise
Here is a ditch I dug with the front end loader alone.. (don’t have a backhoe) I dug this trench for the install of a new drain pipe for a leach bed in the dead of summer (ground was hard as a rock) little bx got through it with out much hassle w/no toothbar.
rkidd
Dec 7, 2015
743
67
Jefferson Ohio
Something to see this old post. Couple years ago when I posted I had 610 hrs, I now have 1210 hrs on my B2650. Been trouble free. Just did the 1200 hr serice which is all fluids and filters. The only non maintenance item was to replace hst switch that went bad.
