How long did your battery last?
tthorkil
M9540HDC12 / LX2610HSDC / ZD1011-48 / Bobcat S250
Jan 1, 2011
323
87
Bagley, MN, United States
2007 M9540 and 2010 Bobcat S250 original Batteries - have used battery maintainer when sitting unused for any length of time for last 10 years.
Bmyers
May 27, 2019
3,394
4,138
Southern Illinois
Purchased mine in 2019 and the battery is still going.
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
26
22
Lakes Region, NH
Purchased my BX2370 summer 2014 and still using the original battery. Have never used a maintainer and have never had to charge it. Tractor is used year round and has over 800 hrs on it. Also have a 2014 Polaris Sportsman 550 with the original battery and never used a maintainer or charger on it either.
mike0000
Kubota L3901, RTV900
Sep 15, 2021
75
84
Southern Indiana
My tractor is approaching 4 years old, I store it in a barn with no electricity so no trickle charger. This winter it turned over weaker than normal. I charged the battery and this spring it seems ok, for now. It’s possibly on borrowed time.
Botamon
Mar 26, 2018
342
632
Winnemucca, Nevada
Some years ago I had the same problem - barn with no power. I found a solar powered battery maintainer with a 15w solar panel and controller and installed the solar panel on the roof of my barn. It has kept the battery on my Miller welder topped off...looked at it the other day and the date I installed the battery was September of 2014. Still starts the welder just fine.
Of course, this is Nevada and the sun shines 345 days of the year. Might not work as well in your location!
Buffalo
L3901, FEL, mower deck
Mar 17, 2016
95
29
Oklahoma
Hmm. I put a battery maintainer on my L3901, and it seems to make the tractor throw codes. If I clear the code and leave the maintainer off, the code stays off. It is definitely the maintainer causing the code. Do I have a bad battery, or a bad maintainer ? Advice appreciated.
armylifer
Mar 26, 2013
2,101
851
Thurston County, WA
That seems really strange. Have you tried another battery maintainer to see if the tractor still has codes on it?
armylifer
Mar 26, 2013
2,101
851
Thurston County, WA
What are the codes that appear? That might give a clue as to what is happening.
Buffalo
Mar 17, 2016
95
29
Oklahoma
I've forgotten, and apparently didn't write it down. (I looked). I seem to remember it was a 'P05 something', which I interpreted as something like "battery overvoltage". Hasn't reoccured since I haven't put the maintainer back on. I did use the same maintainer on a bobcat welder, without problems.
armylifer
Mar 26, 2013
2,101
851
Thurston County, WA
It sounds to me like the maintainer was not shutting off when the battery reached full charge voltage. Conversely, the tractor ECU may be seeing the voltage that the battery reached on the maintainer as being too high. That still leaves the question as to whether the tractor will set the same codes using a different maintainer.
Smokeydog
Jun 2, 2020
737
697
knoxville, Tennessee
Original Kubota battery in 2013 M59, 1600hrs. No maintainer. Wish they all lasted that long.
WI_Hedgehog
Apr 24, 2024
549
672
Milwaukee, Wisconsin, U.S.A.
Some maintainers (such as NOCO) use a high-voltage desulfate pulse (~25V) that pops sulfur off the plates and into solution; this messes with the electronics of some vehicles, and I've read the manufacturer says to remove the battery before putting on the maintainer. Also note NOCO and other brands state they change specifications without notice so your mileage may vary. (For instance, I was looking at a model with temperature compensation, they advertised it as such but had removed it 2 years prior, so the model I was looking at could overcharge/undercharge batteries)
A battery maintainer that desulfates can recover a battery other maintainers cannot. I use a high-end BatteryMinder originally designed for aircraft use (harmonic desulfate instead of voltage) and it recovered many batteries others could not, so in my case worth the money.
A friend with 3 consumer grade BatteryMinder units (no temperature compensation) said all the boiled off his batteries in the unheated/uncooled garage, cheap Schneider units worked better. We have a NOCO on the indoor propane forklift at work (that battery should be replaced...) and it works great. Different units regardless of brand function differently, some work better than others depending on the need.
Blue2Orange
BX2380 with LA344S & QH05. SB1051. SG0554. BB1248. RB0560, Vassar dirt bucket
Apr 3, 2025
61
Bayview Township
Too many variable that effect battery life. Just purchased the BX. On the NH I replaced the lead acid with the Optima Yellow top on day one back in 2001. IIRC, replaced it ~2015. Load tested it a year or two ago. Still ok, but not ideal for our cold winter mornings. Found one on sale and also purchased a battery charger, maintainer. Of course now I go trade in the NH for a Kubota. Dealer was fine with me swapping batteries, but I think the group 51 sized Optima is a bit too tall to fit.
2,909
I run a full size Optima red top in Lil Foot, and it is 15+ years old, stays hooked to an Optima charger/maintainer.
Probably jinxed myself by taking about this one, this battery bit it today, so about 16yrs service from this Optima.
Replacement will be in later today, $279.99. :(
armylifer
Mar 26, 2013
2,101
851
Thurston County, WA
That is more than I want to pay for a battery. I hope that this new one gives you the same or more longevity. Is the new one going to be an Optima?.
6,378
I was surprised a couple years ago when I replaced the battery on my BX.
I got a NAPA battery - - I know NAPA doesn't make batteries, but I've always had good luck with them.
Darned thing was $169. Just a decent lead-acid 26R battery.
I've gotten batteries from other places that didn't last well at all.
I've since gotten a Load Tester, and it's holding up very well. Often has a Maintainer on it.
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
526
484
Lake Almanor, Ca
Just looked the other day…10 years 5 months so far. Sits for months then fires right up.
2,909
Yup, it's on the charger now.
