HomeMade Grapple
555
45
88
Ontario
Hello all just a follow up to my May 20 2023 post on my Grapple I made. As you can see in the pics I put serrated teeth at the end of the grapple thinking it would grab the wood better and hold it. Well it did grab it to well and broke my mount on the stationary end of the cylinder. The problem I found is when I close the grapple it has to be able to have the wood/logs slide and allow the wood to be pushed onto the forks, the serrated teeth would not allow this. So I cut them out and welded in a 2" x 6" piece of car spring that has a slight curve to it, which now lets what your lifting slide not crab it. Hope this helps anyone making their own. Oh and the grapple works great, unloaded a pile of firewood logs of my trailer with ease. Cheers
Reactions: 15 users
2,240
Love to see successful homebuilt stuff!
4,115
me too !!
wondering what bridge is going to fall down without that monster sized rebar in it !!
did you make the cab as well ?
1,963
Love it.
Nice job on the build, and glad its working out.
Greener87
Bx2680
Mar 22, 2024
What did you use for the hydraulic cylinder ? looking to build my own but not sure where to start in acquiring this piece
sardillim
b2650
Nov 24, 2019
111
40
Easton
Nice Job !!!!
555
45
88
Ontario
Hello I used a 3x 8 x 1.25 inch stoke cylinder , it was used. It has lots of power maybe to much but just make sure you build your anchor point on your frame strong. If you buy one at an auction sometimes they leak and you would have to put new seals in them, but sometimes cheaper than new. In Ontario here we have Princess Auto that sells the cylinders, Hyd. hoses, quick connects everything. I know that I have to be careful picking up things that I don't keep putting force on the cylinder because it has a lot of power. Good luck building yours.
Gaspasser
L6060, FEL, forks, front snowblower. KX033 mini ex. Dump truck, Husqvarna saws.
Dec 16, 2023
57
85
NH
Very much admire the job you did. Takes lots of inguinity and effort. Well done.
