Hole or slot?
jyoutz
Jan 14, 2019
2,556
1,658
Edgewood, New Mexico
I‘ve owned my MX6000 for about 6 weeks. Before this tractor, I owned a 20+ year old JD. The JD had a turnbuckle adjustment for the lower lift arms; my MX has the new pin holes and slots design for adjustment of the lower lift arms. I’m wondering which is the best method for adjustment: limit implement sway by using a hole, or allow some sway by using the slot?
whitetiger
Nov 20, 2011
2,619
1,134
Kansas City, KS
If the attachment being used stays out of the ground, use the holes, if the attachment penetrates the ground, use the slots. One exception, a post hole auger, uses the holes.
3,668
While I agree with whitetiger as a general rule of thumb, for me some of it depends on what exactly I’m doing at the time.
Running a boxblade or backblade, most of the time I need the precise and consistent placement that the holes provide. I prefer to avoid squiggly ditches and road edges.
Running a rotary cutter around a bunch of obstructions, I personally prefer the slots to allow a little movement if the deck gets “too close”.
jyoutz
Jan 14, 2019
2,556
1,658
Thanks for the responses. It makes sense, and not any different than I used to do with the turnbuckles.
2,413
For me with a smaller B2910, even using the holes I seem to have a bit of side play. Never use the slots myself.
I always thought the turnbuckles would give the opportunity to reduce side play to zero. Never thought about it the other way. In my experience, I CANNOT limit side play with the existing system of putting pins in holes.
Maybe I am the only one...LOL...will not be the first time...
Creature Meadow
Sep 19, 2016
1,063
135
Central North Carolina
Bush hog-slot
Land Plane-holes
Disk-slot
Row bedder-holes
Subsoiler-slot
Tater plow-holes
As mentioned above, I use the holes when I don't want my implements to drift much side to side
When I may contact something or I don't care then the slots are little for forgiving.
For example when using the land [plane on my road, I run it right next too the grass drift is not good as it could gouge up the grass.
Best of luck.
Jay
