Help!! Kubota excavator won’t start
Vigo
B6100, B8200
Jan 9, 2022
595
341
San Antonio Texas
Well, the good thing is that you have ACCESS to that kind of info and are able to interpret it, etc. As you said, not a mechanic but for not being a mechanic you're able to operate at a pretty high level here where most people would just be stuck not being able to talk to the computer, i think.
So when you get the chance, verify that there is no injector pulse at the connectors. If there WERE injector pulse we'd either be looking at fuel pressure, or a compression problem. But you might already know that a compression problem is often detectable by ear because it will change the rhythm of the engine's sound while cranking. Besides, most 3 and 4 cyls will still start even with one dead cylinder, so it's just extremely unlikely to be engine internals.
So the pulse thing would send you one of two ways: It has no pulse=computer is not trying to run the engine, probably because it doesn't see crank or cam position/rotation. It has pulse=look at fuel pressure possibilities.
Considering you can read the computer already, maybe just check if you can see engine rpm while cranking, that will at least rule out something without getting your hands dirty.
Jchonline
599
Red Feather Lakes, CO
Thats kind of where I was going. Hard to believe it is an internal engine problem.
If it was a fuel/rail pressure problem that would throw an error. If an injector problem, should throw an error. See WSM below. I still think its electrical of some sort.
5,417
2,108
work shop manual makes the task a lot easier.
but in my opinion, it doesn't go into enough detail on how the CR system works, that is in the diagnosis manual-which is part of diagmaster.
Beech123
Kubota kx040-4
Oct 19, 2022
Wv
Thanks again everybody for the advice. I have ruled our cam and crank sensor, (by replacing like a dummy). I figured injectors weren’t opening and thought that could be the problem. Unless I bought bad sensors then that’s not it. Virgo can you explain to me again how to check pulse. Also I keep hearing diagmaster I’m assuming this is a software program. I haven’t found a diagnostic port anywhere. Any thoughts on location
Vigo
B6100, B8200
Jan 9, 2022
595
341
San Antonio Texas
Injectors are usually 2-wire devices. Inside is really just one long wire wrapped around many times to make an electromagnetic coil and what you see coming out is both ends of that wire. Usually vehicles give the injectors power when the key is on, and it's usually shared from a common source (a single fuse). The computer has individual grounds for each injector, and gives the injector ground when it's time to open it.
So on most vehicles you would have power on one side of the injector connector, and no ground on the other side unless the engine is spinning. While the engine is spinning you should have a flashing/pulsing ground on the other wire. It's not practical to check it with a lot of multimeters, but it's easy to see it with a test light. So first you clip your test light to a ground and see which terminal of the injector connector (on the vehicle side of the harness, not the injector itself) has power with the key on. To see ground with a test light you hook its alligator clip to a power source, and it lights up whenever what you're poking with the stick is grounded. So you would then clip test light to power, poke test light into whichever side of the injector connector doesn't have power, and have someone crank it while you watch for pulses.
#37, 38, & 39 on that symptom chart irritate me.. :cautious::rolleyes:
"why doesn't the engine start?" "because it might cause pollution!". Well no shit, sherlock. And how much pollution does the kind of vehicle that can recover a broken excavator cause, when it's dragging an excavator that won't run because of an exhaust sensor? :mad:
Jchonline
599
Pretty sure only Kubota repair facilities have access to Diagmaster……maybe someone can confirm.
Beech123
Kubota kx040-4
Oct 19, 2022
Wv
Ok thanks for the thorough explanation. I really appreciate it. There is a ton about green energy that makes no sense!!
Vigo
B6100, B8200
Jan 9, 2022
595
341
San Antonio Texas
Yes, there are some goofy forms of logic involved. Like, exhaust sensors CANT make your engine not run, but they can make the COMPUTER make your engine not run. Uh, what?
Because manufacturers have to warranty certain exhaust components for certain periods of time. So even though you could take a sledgehammer to all the sensors on your exhaust and the engine itself SHOULD be perfectly happy, the manufacturer will program it to not run if the exhaust sensors are bad, because they don't want your perfectly happy little engine to melt down the filter or catalyst that they would then have to warranty, when they could warranty just the sensor instead. Or heck maybe even say the sensor isn't covered by warranty and make you buy it! There's no legitimate reason for the exhaust sensors to make the engine not start, other than protecting the manufacturer's pocketbook from warranty claims.
But they could very well be the source of your problem according to that chart..
Batsford
Kx0404, bx25
Jan 29, 2025
23
Adirondacks
Me thinks the OP needs to invest in a WSM!
Everyone who maintains (or attempts to maintain) their machine NEEDS a WSM!
I invested in a WSM for my kx040-4. It tells me everything I ever wanted to know about the A/C system but not a darn thing about glow plugs and starting problems……guess Kubota figures their engines are so good they don’t need to share the workings!
Batsford
Kx0404, bx25
Jan 29, 2025
23
Adirondacks
Thanks for the comments. I will order a WSM. I have access to one for an 80 and it seems to be the same setup. The machine is def a common rail. It does have a computer system. I figured out how to get into the system and do a scan. It shows no error codes.
I know the system will show codes due to the fact if I unplug a sensor with key on it throws a fault. I’ve been told that if one injector is bad that the engine will not “fire” due to it being a common rail system. My main thought is possibly a check valve stuck and returning fuel to tank and not allowing pressure to build in system. Not sure if that is possible. Thoughts
I bought a WSM for my KX040-4. While it tells me everything I ever wanted to know about the A/C system but not a thing about the glow plugs and and starting problems! No help at all with your problem or mine!
Hevalery
Kx040-4
Apr 4, 2025
Raleigh nc
Did you e er figure tjis out ?
Batsford
Kx0404, bx25
Jan 29, 2025
23
Adirondacks
Not yet….its been to cold to spend any time in the garage! I did get out yesterday and tried to start it….crank but no start. after cranking it I pulled the dip stick to check the oil, but left it to another project. Tried to start it again and it fired up! But had left the dip stick out so have a mess! Was that just coincidence or am I on to something. Is it possible that built up pressure in the crankcase is causing it not to start and leaving out the dip stick relieved that pressure? I’ll try it again today but get the dip stick right back in!
1,829
There should be some type of ventilation system for the crankcase, probably on the valve cover. I think if it was pressurized the dipstick would be pushed out. But it is odd that leaving the dipstick out would make much of a mess, it would probably spray oil out but would not be any big significant amount.
Batsford
Kx0404, bx25
Jan 29, 2025
23
Adirondacks
I probably exaggerated a little as to how much oil I lost ….yes there should be some type of crankshaft ventilation system…..next warm days project……..sure wish thr WSM included some info on the engine!
whitetiger
Nov 20, 2011
3,107
1,540
Kansas City, KS
The engine has its own WSM and Diagnoses Manuals.
Leaving the dipstick out did not affect the engine starting.
