I run the HF QH and on occasion have had it contact the PTO shaft of my LandPride finish mower. It only happens when I am backing up a bank. The deck starts up the bank and as it rises the PTO shaft comes in contact with the bottom of the QH. Makes a vibration something awful for sure. I thought about cutting the QH right under the top hook and welding in a section of thick walled pipe cut in half to make an upside down U for the shaft to have clearance. That would work, but I hated to hack up the QH.
So, I got some 3/8" x 2" flat stock at TSC and just recreated the lift pin mounts and welded it on top of the existing mounts. Haven't used it yet, but this will raise the QH 2-1/4" higher above the PTO shaft and I think it will work out fine.
Just thought I'd post as I can't be the only one that's ever had this happen.
![](http://i232.photobucket.com/albums/ee238/number9st/Kubota%20L3800/IMG_8277_zpse66b81ba.jpg)
