Grapple
Code
l3301, fel, lp boxblade, 12" lp auger, lp bush hog, z421 zt, lawnvac leaf vac
Dec 19, 2020
142
114
Southwest Idaho
Honestly the SGC0654 would probably fit my use as is really just brush cleanup and carrying 4 ft logs to the processing area
The SGC1060 grapple is a heavier duty grapple than the SGC0660, and it weighs about 150 lbs. more. You would be paying more and giving up lift capacity for a stronger unit. Would the stronger unit be of benefit to you - only you can say? I have had my SGC0654 for over two years. It shows no damage, and I have never been wanting in terms of functionality. I use my grapple frequently; it stays mounted on the loader. However if I am planning to rip out some small bushes, I use my bucket with the tooth bar. Some people dig more in the dirt with their grapples, but they are risking their loader and hydraulic system on compact tractors.
Donystoy
Dec 10, 2013
659
299
Binbrook, Ontario
I will also be just using mine for moving brush and smaller limbs. Anything larger is cut and split where it is. Any digging I do with the back hoe. One thing with the Kioti's twin cylinders is that I have the option of converting it to a dual grabber in the future with minimal fabrication.
3,810
Hell I use the grapple more than I will ever use the bucket! Remember if you aint got some bent tines you aint usin it :)
8,345
Ted of Everything Attachments put out a video today showing an even more upgraded Wicked 55 and it looks great. They've added steel between the tines with "teeth" to get a better grip on trees, roots, limbs etc. I'm going to email EA and ask them if they'll sell those pieces as an upgrade kit for those of us interested/able to weld them in ourselves.
Quick
B2601, LA435, BH70, LP SGC0554 Grapple, LP RB1672 Rear Blade, King Kutter 60" BB
Sep 23, 2021
142
249
St. Clair, MO.
He's a wild man on that 6060! Ted say, "I need a bigger tractor." Hmph... <looks at little B> (-;
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,090
3,329
After watching that, it's official. I operate my tractor like a grandma.
PaulL
2,523
1,472
NZ
I thought I worked my B2601 pretty hard. But it seems I have a fair way to go before I should be concerned.
Donystoy
Dec 10, 2013
659
299
Binbrook, Ontario
Certainly would not loan my tractor to that chap. Would not even consider using a grapple in that fashion. This is why you have appropriate attachments.
McCallum91
B2650
Apr 11, 2025
Ontario, Canada
Yes I bought the Kioti KG2054. It includes all hoses to the two cylinders from the third function. Just have to get the quick connects.
Hey. I just purchased a KG2054 for my B2650. I tried to attach it to my SSQA with no luck. My SSQA upper plates measure 11” and the upper receiving plate on the grapple is only 10” 3/4. I’m not sure if this is just a one off or if they changed the design. Other than the fact that it doesn’t fit on my tractor, it looks like a great grapple.
Donystoy
Dec 10, 2013
659
299
Binbrook, Ontario
Mine fit perfectly. I will measure mine on Sunday for a comparison. Might just take a bit of adjustments with a cut off blade on an angle grinder. Any design change should not affect the critical measurements.
I love the grapple. I have moved multiple boulders, logs and brush with it without any damage.
Donystoy
Dec 10, 2013
659
299
Binbrook, Ontario
Measured mine. Loader plates are 9 1/4” and 44 1/2” total width.
Receiving plates on grapple are 10 1/4” and total width is 45”.
From this it appears that it is the plates on the loader that have to be trimmed a bit.
