So got engine back together last night and fired her up Runs great and no leaks, and no smoke! Thanks all, and especially Wolfman, I couldn’t have done it without everyone’s help. I’m new to these machines and there’s lots of nuances to working with them.
I ran a quick compression test before I put the Intake manifold on and I got:
#1: 360
#2: 370
#3: 380
#4: 380
Huge improvement. This is stone cold with no break-in of the rings whatsoever. Motor sounds good, most of the noises seem to be from the injectors ticking.
Head got new exhaust valves, touched up exhaust seats with my Black and Decker seat grinder, lapped the intakes, and installed new valve seals. Guides were all good. I also ran some 320 glued to my granite surface plate over the deck and head. I used an OEM head gasket, the rest of gaskets are from the cheapest kit I could find.
One tip I can pass on is that , before putting head back on, pull each lifter out. ( one at a time) flush it out with brake-cleaner spray, oil the body and lifter bottom, and reinstall. I flushed out bits of old head gasket material in every one of them when I did this.
Now to get the front axle and driveshaft back on, then it’s back to work! Hafta poke 20 or so holes in the ground for my new pole barn next week!
