G5200 rattle with mower engaged
dlundblad
G5200, L2501, ZD1211
May 16, 2009
503
10
IN
This is with one of my G5200's.
After putting the mower deck on and engaging the PTO, it makes one heck of a rattling/ bearing noise. Almost sounds like something is hitting. With everything off, I turned the blades and can't find a thing. The only thing I have to go by is that the mower worked fine last fall (on a different G) and the tractor didn't make any noise with the PTO engaged before installing the mower. Granted, this would have been without a load.
I've replaced a u joint and splined yoke on the gearbox side, the deck belt, gearbox oil, and deck tensioner pulley bearings. Everything is greased and seems tight with no play. *The deck is clean with no packed grass on the bottom by the way.
4,430
Maybe it's the propeller shaft in front of the fan. The connections at both ends of the shaft could have some wear and the extra load causes them to flex.
dlundblad
May 16, 2009
503
10
IN
It turned out to be the entire u joint assembly.. most likely the gearbox side since that has the new stuff. In my original post, I forgot to mention I also replaced the yoke that connects to the mower's gearbox.
I had a complete replacement that I swapped out and the vibration went away. I'm glad the issue is fixed, but frustrated at the same time because I don't know what the original issue was.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,140
938
Williamstown Ontario Canada
If the drive-line you removed has smooth operation and no play then other issues need to be considered.
This information is more intended to alert you to certain phenomenon associated with simple U joints which are unlike modern front wheel drive cars constant velocity axle joints.
https://www.youtube.com/watch?v=Idk3BVDVHq4
Phasing is the process of aligning the universal joint yokes on both ends of the drive shaft (or double u-joint)in a parallel fashion. If the joints are not properly phased, they will operate at varying speeds throughout each revolution which can cause second-order vibrations.
https://www.beldenuniversal.com/phasing
Dave
dlundblad
May 16, 2009
503
10
IN
I'm using Kubota parts so theoretically, the angles shouldn't be incorrect.
Also, the splines have a slot that allow for only one way to go together.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,140
938
All good. What I have seen in the past is a machinist shorten or lengthen a pto shaft for a friend and they fail to index the shaft and suddenly the shaft is vibrating like crazy.
You could take the old shaft to a truck place specializing in drive lines. Ask them to balance it. In doing so they will find if it is slightly bend. Something is making it vibrate and they are so expensive you do not want o just throw it out as unusable.
Here are links to two such shops
http://cincinnatidriveline.com/?cam...Jf4z2NxG50kWLTANnImpe3GFvUecmoBIaAjt2EALw_wcB
http://www.perfectiondriveline.com/...3xpspc0xBINCDKFidpXAv91WJ3q8kf0AaAgDgEALw_wcB
Dave
dlundblad
May 16, 2009
503
10
IN
Dave
Thanks for the links. Yeah, these parts are somewhat hard to find.. the male splined part being discontinued apparently so there will be no tossing it into the trash.
We have a drive line shop locally (Fort Wayne Clutch) that I've thought about taking it to for a balance and/ or an answer as to what's going on.
