G2160 mower - Alright to use AW ISO32 hydraulic oil instead of Kubota's UDT?.. top up or change out?
Rober88
Kubota G2160
Aug 4, 2024
14
I've never maintained a riding mower before and haven’t changed any fluids. Two years ago, my brother-in-law added AW ISO32 hydraulic oil to the transmission, but Kubota recommends UDT. I just checked the transmission dipstick after running the engine, and it’s dry.
Can I top it off with the same AW ISO32 (there’s still plenty left, though it’s been sitting in a barn for 2 years)? Also, the drain plug is apparently seized or stripped, according to my brother-in-law.
4,843
NO, NO, NO!!!!
The tractor needs a tractor transmission fluid. AW hydraulic oil is a different animal!!!
6,449
NO, NO, NO!!!!
Dan - I was hoping you’d chime in.
I don’t know what the other stuff is but figured you would. …..
4,843
AW32 is a conventional hydraulic oil used in industrial applications. It lacks the application specific addirives used in tractor transmission oils (e g UDT or generics)
Rober88
Kubota G2160
Aug 4, 2024
14
Just went through a bunch of threads on the internet —looks like AW32 isn't ideal for transmissions and can damage seals. Pretty upset right now. I’ve noticed a fair amount of oily residue around the transmission, and I’ve attached a photo showing a rubber string near the back of the transmission case.
Turns out my in-law added about 2.5 liters of AW32 roughly two years ago. I estimate it's been running that way for 100–150 hours since my in-law put in the incorrect oil.
Rober88
Kubota G2160
Aug 4, 2024
14
NO, NO, NO!!!!
I'm guessing there was a 50/50 mix of old UDT and AW32 for the past 2 years. I'll be draining that oil and putting in UDT tomorrow.
Do you think there's been a lot of damage? Any advice?
4,843
Turns out my in-law added about 2.5 liters of AW32 roughly two years ago. I estimate it's been running that way for 100–150 hours since then.
My G2160 has never seen anything but SUDT2 and still leaks. Your issue is most likely age not oil. Drain and refill with a good UTTO if you are concerned about cost.
Rober88
Kubota G2160
Aug 4, 2024
14
Dan, do I really have to clean out the Transmission Oil Strainer?
