G1800 Lawn Tractor idles rough
Bllowns
Kubota G1800
Jun 27, 2023
Ooltewah, TN
I have a Kubota G1800 lawn tractor three cyl diesel. When the mower tilts to either side, after a few seconds it starts to run rough and the engine starts loping trying to die, and sometimes it does die, but will start right back up. If I stop the mower and shut of the blades off, the engine will pick back up and will return to a smooth idle. It only happens when the mower tilts to one side of the other on a slop. Could it be some type of fuel delivery problem or a fuel filter?
Torinodan
T1600, G4200, G5200, Ford 2810, 1974 Wheel Horse C100
Oct 14, 2021
195
89
Fayetteville GA
If it was water it wouldn't restart so easy. Sounds like you have a chunk of crud in you tank. I suggest removing it and flushing it out. I have a spare 1600 tank that the bottom was full of black sludge and wouldn't drain.
StephenR
30
14
Kentucky
It sounds like a fuel delivery issue, But I have been wrong about most everything I try to diagnose without seeing the machine. I would look at a filter issue maybe in the tank. There could be something that is blocking the fuel from getting out of the tank. Good luck.
Bllowns
Kubota G1800
Jun 27, 2023
Ooltewah, TN
I haven't thought about the tank. Thanks so much, I will explore that possibility and see what I find.
Bllowns
Kubota G1800
Jun 27, 2023
Ooltewah, TN
Thanks so much. I will check the inside of the tank and see what I find.
