have a Kubota G1800 spewing oil from the front of the engine (16 HP Kubota D662 diesel engine). Hard to see where the leak is from as pulleys and flywheel is in the way. I have pulled the PTO pully and flywheel to be able to see. In the center of the picture is the front of the crankshaft (five bolt holes). Just around that is a black "Seal Oil part 09560-00007" Outside of that is the Cover for the bearing case (16 bolts). The bearing case cover has a gasket under it.
Question: I am trying to figure out should I just replace the Oil Seal Part, or is their a possibility that the leak is from the gasket of the bearing case cover. I don't want to remove and replace more parts than I have to. I've never looked under a bearing case on the front of a crankshaft on any engine, so insight from others would be helpful.
Thanks, Rich
Thanks, Rich
