CaveCreekRay
Speak8,
I feel for you man! I have the spout still floating around in my tank. I spent an hour fishing around with various tools trying to snatch it but, no luck.
That tank is a bugger to get out. You either have to pull the instrument bezel and the surround, or take out the motor... not sure which. Not Kubota's fault!
I am going to fill it up to the filler neck and the drive it around on rough terrain and see if the filler neck will float up enough so I can grab it. The tank is so convoluted toward the bottom it makes it almost impossible to reach with tools readily available.
Take a hint from both of us -DON'T GO NEAR YOUR TANK WITH ANYTHING THAT COULD COME LOOSE! ITS A LOOOONG WAY DOWN!!!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
