Fuel Leak b6000
cainbr
B6000
Jun 12, 2014
Hartford City
Noticed fuel leak. Just need to know how to fix it, is there a gasket or something. I tried to tighten the 2 nuts. But it still leaks.
5,214
Yes there is a gasket in there:
P/N 17011-53620
JerameP82
B6000E
Aug 15, 2014
Asher, OK
I am having a fuel leak in the same exact spot, however I changed the gasket and it still leaks.. the injector has a loose fit any ideas? my next plan was to buy a new injector assembly.. but I'm worried it may be the head itself
Big Trees
119
JerameP82, I'd be interested if you ever found out your problem?
I am having a leak from the same spot and have NOT yet replaced the packing there. I am going to and figured that would take take care of my leak but I came across this post and saw you still had a leak after replacing the packing.
Does anybody else know what the other causes for there still to be a leak if the packing was replaced?
Thanks.
djmc35
4 Kubota B6000's, Cub Low Boy, Sears tractor w/FEL
Jun 19, 2014
79
Bloomington, IN, USA
Sorry you guys have this problem. I have it also. I changed the packing or copper crush washers and it still sprays fuel out. One theory was perhaps I cracked the Injectors. $250 to do both is a little pricy to do on something that may not work?? No one seems to know the correct torque for the injector hold down bolts? If either of you Gentleman find a solution Please let me know? I will do the same!:)
