FS: Kubota B7100 dozer blade / plow setup
AOW162435
B7100
Jun 16, 2023
95
49
Ellicott City, MD
I am selling the original Kubota front dozer blade / plow that came with my 1979 Kubota B7100 4WD. This is a complete package - the plow, the plow subframe, the semi-permanent subframe that usually stays on the tractor, the hydraulic controls tower, and all removed bolts & fittings.
It's obvious from condition that this setup was not used much. I purchased the tractor last year to only use with a rear mower.
This is a 2-way plow setup, meaning that it raises & lowers hydraulically. Left & right tilt can be changed using the supplied hitch pin, or with the two bolts & lock nuts (supplied).
Although this was originally fitted to a B7100, I would be surprised if it didn't bolt right up to a B6100, etc. Please do your own research on this.
I am selling the entire package for $1,800, and am located in Ellicott City, MD 21042.
NOTE: I pictured my tractor simply to show what the plow was attached to when I purchased it.
