Front blower L4474 vs L4479
Dave111
BX2200, L6060
Aug 24, 2023
MD
Why would it ride on either side? Does you drive have excessive crown? I have a L4479 and am not using the shoes. It rides evenly on the cutting edge, and does not ride on the ends. I would not want to use the shoes on a paved driveway as it wouldn't scrape clean.
I know all about wanting to scrape it clean and used to do just that with my BX and its blower, when I did the driveway with that (now use the L w/cab and L4479). That was some time ago and the driveway was in better shape. It is unfortunate, but the driveway is not level and actually has a few crowns! It is a long common driveway, in addition to my own. It was all incorrectly done years ago (actually got all the money back for it) and as time went on people drove on it (as well as all the Amazon, Fed Ex, UPS, etc. deliveries) there are actual tire indentations within the pavement along with a few developing holes. I have the shoes set about 1/8" -1/4" lower than the cutting edge and follow up with a rear blade that I have fully lowered as a 'sacrificatial' scraping edge that gets the top as clean as I can.
HorsPower
Kubota L5740 HSTC-3 Cab
Nov 5, 2017
24
11
Maryland
Understood, that is unfortunate. That said, unless the driveway is chunking / breaking up and you are concerned about running chunks of asphalt through your blower, it still sounds like you would be better off removing the shoes completely. Your replaceable cutting edge will take the wear and still distribute the load better than the two small shoes.... and you don't have to worry about the shoes running off the edge of the driveway since the blower will be supported all the way across.
If your application still merits you using skids.... here is a new thread you might find interest in reviewing:
