Front 3rd Function Flow Rate?
GrizBota
Apr 26, 2023
1,143
728
Oregon
Not 100% sure this is what you’re looking for, but the specs on the implement pump are 37 liters/minutes (about 9.8 gpm) as per this link. Grand L 40 Series Glossy
Edit, well looks like Dan helped us out, this is what you’re after.
3,453
Not 100% sure this is what you’re looking for, but the specs on the implement pump are 37 liters/minutes (about 9.8 gpm) as per this link. Grand9 L 40 Series Glossy
Your the guy that pulled up the actual specification. (y)
Want to bet Kubota assumed 100% volumetric efficiency when they came up with that number?
:devilish:
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
1,789
869
Near Lancaster, PA, USA
Thanks fellas! I know very little about hydraulics on a tractor. That appears to be what I'm looking for. Right now there's no application, but it's one of those bits of info that may come in handy. There could be something with a small hydraulic motor as part of a project, etc.
GrizBota
Apr 26, 2023
1,143
728
Oregon
Going to get you a “Lame” Shark?🤔😁
chim
Jan 19, 2013
1,789
869
Honestly not sure what could happen. Knowing the flow rate is a useful piece of information though. There have been times when some sort of LS or sickle bar would be handy. Maybe just a motor as part of a small conveyor, some hydraulic tool, nothing planned. If something looks like it could be a useful gadget run with hydraulics then it would be time to get serious and research it.
3,453
When/if you get serious I would suggest you figure about 85%-90% of Kubota's published specification. Thats the rule of thumb for gear pump volumetric efficoency. I suspect Kubota simply calculates pump displacement x RPM without any allowance for pump (in)efficiency.
