Forward And Reverce Pedal Blowes 5 Amp Panel/OPC Fuse
rancher1524
Tractor LX4020 B3350SU
May 11, 2016
108
20
Evans, Washington
I have a Kubota B3350SU that starts fine but when you depress the Forward and Reverse Pedal the engine stops and the 5 amp fuse for the Panel/OPC blows. I checked all the wiring for frayed or chewed spots and found none. I removed the Neutral Safety Switch and tested it for continuity and it worked OK. I jumped the Neutral Safety Switch plug and the tractor started and drove fine in forward and reverse without blowing the 5 amp fuse. Could the Neutral Safety Switch have an intermittent short causing the 5 amp fuse to blow.
whitetiger
Nov 20, 2011
2,679
1,180
Kansas City, KS
Yes, it is not uncommon for the hydrostat control pedal safety switch to intermittently be shorting to the ground which can blow the 5 amp fuse.
