Fish Lifes B6100 Restoration
FishLife
177
Destin, Fl
*This thread is about the complete restoration of my B6100*
So, I have to address the low oil pressure issue. Already took the oil pressure sending unit out and used a gauge and confirmed I do indeed have low oil pressure. I suspect the the plug in the cam fell out as other have experienced.
During my test thought I noticed the gauge only read 3-4 psi higher at half throttle vs idle. I still plan to go in and check the plug but what are the thoughts on the oil pump and the relief valve?
5,123
Re: B6100 Low OIL Pressure Fix
Most likely neither the oil pump or the relief valve will be the reason for the low oil pressure, both of those are just about bullet proof, but for grins you can easily pull the relief valve out when you drop the frame before you take the gear case cover off. ;)
FishLife
177
Destin, Fl
Just wanted to check. I'm looking at the parts diagram trying to put a list together of the parts needed for the repair. does this symbol (<=) mean before a certain serial number and this (>=) would be after?
FishLife
177
Destin, Fl
Also is there a post that someone has done a step by step to shoe the process or a video? I tried a search but unless its buried deep in a thread I couldn't find one.
5,123
Yes it does. ;)
FishLife
177
Destin, Fl
This may be a stupid question but I have know idea and I dont see a reference in the WSM. Is it necessary to drain the oil before removing the gear case cover?
5,123
Yes as the oil level will be above the bottom of the gear case. ;)
5,123
Thanks. I also have to replace the rear main so I know it would have to for that. Since I already have the axle off, I will just pull the engine and put it in a stand.
Note that there are two different gaskets on the rear main bearing holder, order you'll need both.
Guy from Canada
B6100 Bulher Allied 95 loader, 46 Meteor Snowblower
Dec 12, 2017
Oakville Ontario Canada
I have come across a couple of YouTube videos that might be the cause of your low oil pressure. There is a plug on the front end of the cam shaft that comes out causing a low oil pressure light to come on. Just my two cents worth.
FishLife
177
Destin, Fl
Thank you. I mentioned that in my first post.
FishLife
177
Destin, Fl
Well sure enough the plug on the cam fell out. Couldnt find it so it probably got chewed up by the gears. Im getting ready to leave to go out of town for a week so i will have to wait till I come back to get it back together. I know what now what all seals I need so I will go ahead and order those so they will be here when I get back.
FishLife
177
Destin, Fl
Figured out how to have my pictures show in the right orientation when i post. Apparenty I have to have my phone sideways when i take the picture.
4,392
You may be able to find the plug in the bottom of your oil pan. Need a magnet you can reach around with.
And you may have mentioned the cam plug problem "in the first post" (that Guy From Canada mentioned) , but that was a different thread, I'm pretty sure. You might be better off leaving your conversations on the plug missing all together.
FishLife
177
Destin, Fl
If that came across as being snarky, Im sorry. I was just stating that I mentioned it in the first post of this thread. I’m in no way trying to turn down any advice from anyone who is trying to help. I once again apologize if that’s how that was interpreted.
4,392
I didn't take your answer in a negative way, it's just that folks may not have seen/read all your threads you have on this. You will probably get more responses if you keep it all together. You get some answers/ideas on one thread and then start a new one. This causes lack of continuity/confusion.
I do think if you look at this particular thread there is no mention in your first post about this cam plug falling out. That's why he probably commented as he did, just trying to participate/help.
FishLife
177
Destin, Fl
I just thought it would be easier for folks to search by starting new threads with each topic. Instead of one that could get very long and cover a wide range of issues that folks would have to read through if searching for a solution to a problem. I may be wrong and just cluttering up the board.
5,123
I'm keeping an eye on the threads, if it gets too cluttered I can combine those that need combined. ;)
I will mention that your other Thread "B6100 The Saga Continues." to me just comes across as a "poor me" or "complaint thread"., not a knock just an observation. :)
You are dealing with a 40+ year old tractor, count your lucky stars that you got one is as good of shape as you have, The B7100 that I'm working on makes yours look like a cream puff.
On the cam plug, I'm thinking that some of the early models were aluminum and might have just went poof (ground up by the gears) or yea as D2Cat said, it's in the oil pan.
Make a new plug and tack weld it in or if you can't weld, tap the cam for a threaded plug, that's the way most newer cams are done.
FishLife
177
Destin, Fl
Northern Idaho Wolfman, Ya that Saga thread you can delete that if you like. It not very helpful to anyone. I wrote it late and was kinda ranting. I will keep to the point for now on. Hope Im not wearing out my welcome.
I can weld and Im just going to turn a plug and weld it in.
