H Hori New member Equipment FEL Apr 17, 2024 1 0 1 Whangarei Apr 17, 2024 #1 I have a Kubota L295 DT wanting to know if a Ford 2600 FEL can be fitted to the Kubota L295 DT
G GreensvilleJay Well-known member Equipment BX23-S,57 A-C D-14,58 A-C D-14, 57 A-C D-14,tiller,cults,Millcreek 25G spreader, Apr 2, 2019 10,050 4,139 113 Greensville,Ontario,Canada Apr 17, 2024 #2 Sure, take a zillion measurements, cut/hack/weld as required. Also be SURE Ford cylinders are compatible( pressure/volume ) for the Kub's hydraulic system.
F fried1765 Well-known member Equipment Kubota L48 TLB, Ford 1920 FEL, Ford 8N, SCAG Liberty Z, Gravely Pro. Nov 14, 2019 6,832 4,303 113 Eastham, Ma Apr 17, 2024 #3 Hori said: I have a Kubota L295 DT wanting to know if a Ford 2600 FEL can be fitted to the Kubota L295 DT Click to expand... Maybe try a Cat 955 loader? It will lift more! Reactions: 1 user
TwitchyMcJoe New member Equipment 1980 L185DT Mar 25, 2024 21 20 3 Waynesboro-Staunton-Harrisonburg, VA Apr 17, 2024 #4 Hori said: I have a Kubota L295 DT wanting to know if a Ford 2600 FEL can be fitted to the Kubota L295 DT Click to expand... Does the L295DT take the L1200 loader from other L series tractors of the same era? You might find an L175, L185, L245 etc. With a loader you can use.
