F2560
RyanBX2200E
Kubota BX2200, Kubota B6000E
Jun 30, 2018
U.K.
Hi all. My F2560 out front has a problem. When I’m driving it’s hard to stop and when it does it’s very abrupt. Also it’s a struggle to find neutral and for it to stay there. Hope somebody can help. Thank you.
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
That particular machine appears to have wet disc brakes. The only suggestions I can offer are to check the fluid level and adjustment.
whitetiger
Nov 20, 2011
2,612
1,131
Kansas City, KS
Put it up on jack stands so you can get under it. About where the battery sets, inside the frame, is the neutral linkage. It consists of a "V" shaped arm, another arm with a spring attached and a bearing mounted on it. The spring pulls the bearing into the "V" to obtain Neutral. Usually, the bearing has failed or the spring broke. It is very simple once you look at it.
RyanBX2200E
Jun 30, 2018
U.K.
Ok great i will investigate and come back to you. Its strange that when the machine is not running the pedal seems to return fine. Thank you.
