Engine oil interval
OldcrowP51
Kubota L3901HST, RCR1860 rotary cutter
Aug 18, 2021
66
Minnesota
It is recommended to change engine oil in the Kubota every 200 hours.
I average about 75 hours per year.
It would take about 2-3 years to reach that 200 hour mark.
Any issues waiting that long?
My tractor does very little idle time.
Normal use is at 540 pto speed or above.
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
25
NH
Manual doesn't state this, but the maintenance schedule for a lot of other engines state to change oil by hours or every year or two years, whichever comes first.
In areas with cold temperatures (like Minnesota!), condensation and other contaminants will build up in engines and settle in crankcase. Changing oil will flush this out.
I normally do more than 200 hours in two years, but if I didn't, I would change it every two years.
Flintknapper
L2350DT
May 3, 2022
1,892
2,377
Deep East Texas
Even in warm climates (where I live), if there is high humidity, the same thing will occur. Generally, I'll use my tractor long enough that the oil in the crankcase heats up well and any water 'vapor' has chance to escape from the vent.
Even so, I change the oil and filter religously at 100 hrs operating time.
Not hard to do on my tractor and not expensive.
My L2350DT is 28 years old, still going strong.
BBFarmer
Jul 12, 2024
310
575
Terry, MS
That's just it. Mights as well.
Mines every 400hrs. At that rate, My first tractor would've still been on its first change LOL.
Im comfortable with once a year on oil and filter. A filter and a little rotella is cheap enough and takes less than 10 minutes out of my day.
Blue2Orange
BX2380 with LA344S & QH05. SB1051. SG0554. BB1248. RB0560, Vassar dirt bucket
Apr 3, 2025
73
22
Bayview Township
Oil and filters are relatively inexpensive. Effort to change is minimal. Maintenance vs. repair. JMHO, at least every other year or hours. Which ever comes first.
That said. I got lazy with the NH. First decade ownership was a bit OCD when it came to maintenance. Second decade just stuck to every other year or hours "rule". 3rd decade got lazy with low hours of use. Every 3rd year came around sooner than the hours.
New BX. OCM (obsessive compulsive maintenance) syndrome has kicked in. By the 3rd decade of ownership I will probably be worm meat or dust in the wind.
William1
BX25D
Jul 28, 2015
1,192
393
Richmond, Virginia
Oil, every year, filter, every 100~150 hours (Two or three years).
First change is very important. Even if well less than the manual 50 hours, oil and filter.
Too many changes is 100X better than not enough.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,091
3,329
Dont look in the orange cook book. Every single major oil brand tells you not to go more than a year. That's all the info ya need.
kcs 61
B2650 , BH77,FDR1660, PFL2042,RCR1860,RB1672, RTR1258,BB1260
Apr 8, 2024
30
17
Va
I put 50-80 hours a year on my tractor. I do an oil and filter change every year with a fuel filter change at the same time
6,467
I normally do once a year. Had a couple mild winters/lack of dirt work and I only put 30 hours on the tractor in a year.
Let it ride for a while, but not 2 years’ worth.
