Electrical - Wiring Diagrams
Hydro
ZD21
Sep 3, 2024
10
Southern Indiana
Needing a wiring diagram for a B2630 -- mainly the part for the OPC -- blowing the 5 amp fuse randomly
EDIT
after searching I found the diagram here --editing to add the diagram to the wiring section
eschap
lots of kubota ag equipment
Jan 21, 2024
Chelan Washington
I discovered the hard wY that the wsm fir new l4060 etc has the wrong hst setting procedure under test preparation. The error is "setting the range seleter to nuetral between L and M" the correct one is select nuetral between Mand H.
Now the process will begin. And fyi contrary to some "kubota does not require a laptop to service or program these settings, it's all done through the display
