Drain port on backhoe
Hman0217
Kubota l3901 hst
Aug 12, 2021
Catskill, ny
Hi I have the bh77 backhoe on my l3901
Ive been trying to purge water out of the hydraulic system on the tractor but the backhoe was disconnected over the winter and I'd like to drain as much as I can before I hook it back up
Are the bolts pictured supposed to be drain ports for hydraulic fluid? I imagine there must be a way to drain without connecting to the tractor, yes?
ayak
L3301 HST
Feb 16, 2018
673
922
WV
Here’s the relevant page from the BH77 WSM, if it helps. I would think whatever fluid is sitting in your cylinders right now far and away exceeds whatever you might get from messing with that valve stack.
8,184
No those are not drains, there are no drains.
The BH does not have any reservoir capacity.
In order to move any fluid in the cylinders you need to hook it up to the tractors system.
