Draft control M5660 SUHD
Ted1
30
Pa
I bought one of these tractors which I really like. However, it does not have draft control which I knew when I bought it. Now of course I wish I had it. Is there any way to add it to this tractor if done by the dealer? Thanks for your time.
BigG
Sep 14, 2018
1,951
767
West Central,FL
Why do you need it? Just asking. Most of what draft control does can be done by listening to your tractor. Unless you are doing a great deal of say, plowing.
Ted1
30
Pa
Think it would be helpful in plowing where the ground is not perfectly level. Plows don't seem to stay at same depth .
BigG
Sep 14, 2018
1,951
767
West Central,FL
Which tractor do you have? Was it an option when you bought the tractor? Sorry I was looking at your profile and it did not show which tractor.
I do not see draft control in the brochure as an option.
BigG
Sep 14, 2018
1,951
767
West Central,FL
How big of plow are you using? Is there an adjustment on the plow to set it level? If not you might try to lengthen the right side of the 3 ph so the plow is a little more aggressive. The bad part is it will reduce your fuel economy.
SidecarFlip
Banned
551
You cannot add it because the draft sensing is linkage and vlaving plus the top 3 ph mount is not stationary, it moves and requires a stop block to actuate. Retrofitting would entail a complete PTO end replacement because the PTO cover is part of the draft sensing components.
SDT
multiple and various
Apr 15, 2018
3,095
942
SE, IN
Lack of mention in the sales brochure is not determinitive.
Not certain about the M5660 but draft control is optional on the GL6060 and similar models.
Try the build it site to find out about the 5660.
That said, the draft control system on the smaller Kubota models is a bit of a Rube Goldberg and you will likely find it more trouble than it is worth.
SDT
