Does anyone know if there are aftermarket cylinders
3,510
This looks like a pretty good fit - $410 for a pair.
Clyde Smith
Kubota B7510 LA302 LOADER
Apr 30, 2024
20
Jacksonville Florida
I know the kubota hose fittings are metric do you know what fittings will be needed to install these cylinders
3,510
Are you sure they are metric? That would be unusual for Kubota. My guess is they are either BSP or imperial.
The ports in the cylinders SAE so adapters will be easy to find.
Clyde Smith
Apr 30, 2024
20
Thanks for the help I ordered a pair of cylinders hope they fit so I can get this kubota working for my father in law he's 82 and really likes this little tractor
1,024
Looks like you may need to figure out some spacers for the one end with the pin. I think you might have to get something machined to fill in the gap?
3,510
I would not bother but if concerned a hacksaw and one inch pipe nipple should get it done in short order. PVC would work just fine.
BAP
Dec 31, 2012
2,552
682
Why not just buy the parts to fix your cylinder? If you only need the end cap and seal kit, it’s cheaper than new cylinders. Parts break down is listed below. Check to make sure that’s the right cylinder, if not go to another page in their online parts book.
