Hi Guys, This is not about my 4500DT this time but same principal. I have a 1997 Mitsubishi Canter 6 tonne tipper and I have replaced the pinion and carrier bearings in the diff.
I needed to add a 2 thou shim on the pinion because the preload was too tight (these have a non crush sleeve type spacer). Before I put new bearings on the pinion I honed out the old ones so I could easily slip them on and off to try out different shim thicknesses. The spacer/shim is between the pinion head and bearing, so it difficult to take the new one off each time to try shims.
The original contact pattern was terrible, drive side near the toe and triangular or some of them dome shape (sunset as they say) I didn't have the correct size shim for under the pinion head so I cut one down to fit the shaft.
It was about 10 thou, about I/2 the original shim( 20 thou) under the pinion. This didn't seem to make much difference where the drive side contact pattern is.
I thought maybe just putting in the new bearings would get the pattern a lot closer to original ( original shim now put in).
These are pictures I have of my contact pattern. The coast side looks ok but I assume the drive side is too deep and close to the toe. I adjusted the backlash between the min/max specs at 8 thou to 12-14 thou.
there is a slight difference of the pattern coming in from the toe (two lots of drive pictures) but it is triangular and I am assuming is too deep in the tooth, and too near the toe. therefore from all the patterns I see on the internet I must, increase the pinion depth (lessen the shim thickness). Is there anyone who can help with an educated guess as to what shim size I should try. I dont want to keep taking this bearing on a number of times and off as its easy to damage.
Final comments, this pinion and ring gear still has meat on it, but it could be worn unevenly and giving me a bad tooth contact. Bearing preloads are correct on pinion and carrier, and backlash I adjusted a few times. Runout is just within spec of the manual at 4 thou. I put pressure on the ring gear as I turned the pinion.
Thanks, any advice will be helpful.
