I recently sold a good amount of my property so I am looking at downsizing my tractors. I currently have an ancient Ford 641 that I used for site work such as (dirt) plowing and grading and an 861 with a loader and backhoe that I used for everything else. I'm going from ~100 acres to 2 so obviously 2 big old tractors will get in the way. I'll be using the new tractor for light garden work and landscaping, firewood moving, as well as brush clearing and snowplowing. I'll still have around 500' of driveway to snowplow to my new barn but I won't be doing any large amount of farming or logging anymore. My old tractors run just fine but they're big and smokey. I'm really thinking that I'd like a nice modern HST equipped tractor so I don't have to fight with the clutch and struggle with the heavy cat 2 or 3 whatever it is implements.
Initially I thought either a Mahindra Max 25, JD 1025R or Kubota BX25R were the right tractor for me. After looking at the Mahindra it seemed a bit too much like my old tractors. Plus although it had a split brake which I really wanted it was also on the same side as the HST pedals which confused and annoyed me.
The 1025R is a decent tractor, it seems fairly ergonomic and it's a bit bigger and heavier than the BX25R so you could probably do heavier work with it. It seems to have smoother and faster hydraulics than the BX25R. I'm just not completely sure that I value the 1025R as much as the dealer does.
The BX25R seems like it is a really nice tractor. It looks like it will do everything I want. Eventually. It is much smaller than anything I've used before. It seems that a main selling point is the mid mount mower but I have a lawn mower so I won't be taking advantage of it. The frame mounted plow and all the implements are on the small side but watching people work with it on youtube it seems to get the job done. I'm looking at $20500 give or take after taxes.
When I expressed my concern over the size of the BX at the dealer he pointed me towards the B2301. It's more of a size I'm used to, it picks up more, it looks like it would have an easier time plowing and the backhoe is bigger. It has split brakes which I use on my old tractors every time I'm on them. However it costs more and is bigger. I won't really be "downsizing" if I move laterally to something just as big but with less power. I'm not sure I "need" the bigger tractor but then the dealer is telling me it has a sharper turn radius than the BX and of course with size comes capability. The loader lifts 500lbs more I believe and it has the separate hydraulic pump. The thing is I think everything I've mentioned as a benefit of the B2301 the 1025R has. They seem more comparable than to the BX. $26000 after taxes isn't that much more but it's more.
I guess I'm looking for someone to talk me into the BX25R instead of the 1025R or B2301. Besides "more" what can the B do that the BX can't? For basic homeowner maintenance, patio construction, foundation digging and the like besides time what benefit would I have with the B over the BX? I'm thinking the BX will tear up the yard less and will fit into tighter spaces but then heavier lifting is nice. However I'm wondering how many times I'll be using 1000lbs of lifting capacity. The BX will still move the gravel around just slower. On the other hand speed is nice. I'm in analysis paralysis.
