Dang!
Dstudder
L4330, FEL, etc
Jun 27, 2014
Lancaster, VA
Dang! L4330 GST won't start.
I have an 2004 L4330 GST with FEL, 460 hours. Was bush hogging a field yesterday, ran over a large stick that jammed under the floorboard on the left side. It damaged 4 wires in the wiring harness and cut the tractor off. I repaired the 4 wires, but now it will not start, will not even turn over. The dash display says the PTO is off, but the PTO Warning light in the lower left corner is still on. It appears that a sensor is damaged. The PTO Warning light is for the Mid mount PTO, which I do not have. All I have is the rear PTO. Any ideas?
Dstudder
L4330, FEL, etc
Jun 27, 2014
Lancaster, VA
All fuses are OK, as well as the battery. Disconnected battery to reset ECU and hooked up charger. Still nothing.
