D600 vs D650?
MikeHall
23
Leesburg GA
I have a B6100 that needs an engine. Would a D600 bolt up as a replacement engine? I understand it would be less power but if it bolts up it may be a way for me to get my tractor going again as I found a engine for sale locally.
5,318
Actually a little more HP with the D600.
I don't know if it will work or not as they are 2 different series of engines, you can go with a D650, D750, D850, and D950 with minor changes, all are the same block and same flywheels.
It's a long shot that everything would match up. ;)
MikeHall
23
Leesburg GA
Its crazy how little info can be found even when exhausting google to the very last page on these engines. :mad: If the engine would bolt up, i would figure out how to get every thing else working. The engines look nearly identical from the few pictures I can find for reference. I have noticed that the D650 has a cast bell housing where as the D600 has a sheet still adapter for mounting to whatever it was used on. I sure hate to pass up a complete good running D600 because I just can not find out if it would bolt up. The engine is about 2 hours away so its local but not local enough to go look and not bring it home. :D
mrmr56
G4200, Z482, 3 G5200's
Jul 22, 2015
Waco, TX
I would stay away from a d600 for future use. This was used in Kubota garden tractors and some industrial applications. Parts are not readily available at a decent price. I have 3 of them and I intend to keep them for spare parts in the future. The 650-950 series engines are a newer design. Just my 2 cents worth.
5,318
Mike,
One other thing to note:
If you have a 4wd then it probably will not work as on yours it has a pan that allows the driveshaft to go through it. ;)
