Wondering if anyone has seen this before and can give me some idea as to what would cause it.
I have a B9200 HST. Purchased used about 10 years ago. I'm at least the third owner. I don't really know how many hours on it since the meter has only three digits.
I split the tractor to replace drive shaft coupling and was really surprised at the wear on the clutch disks splines and shaft. The pilot bearing was completely gone.Photos attached. I would not expect that kind of wear on a HST.
A few years ago I put a new clutch in a sub compact tractor I have that has a gear trans. I've had that tractor since 1986 and used it to bush hog, loader work, some post hole digging, and snow plowing. The clutch disk was worn as was the release bearing as I expected with the type of use. But there was no wear on the disk splines.
