Trying to learn about my..new to me...B7500hst. In the manual it makes reference to a water drain plug to drain water from the clutch housing. I locate what I assume to be that drain, in the rear of the bell housing. Remove the plug...and out come what I believe to be hydraulic fluid. The pic in the manual isn't terribly helpful...so...Is this the correct plug??? The manual also references a "front transmission drain", which looks similar in position. Thanks in advance. The first pic is the manual reference....the second is the plug I removed.
