Hi all,
I'm battling away with my little B5100E. Found the clutch seized when I came to starting her up.I striped her down to look at what was wrong.The main reason for my sticking clutch problem was rust but there is also severe wear on the clutch release levers ,see the 3rd pic one of the levers has the bearing landing/contact point worn off. I've priced replacement parts and I'm still dizzy.Replacement levers by 3 =€90,pressure plate €270,clutch disc €237, release bearing €33=€540 for a new clutch....this little tractor is only worth that when its running!!!I have attached pictures of the parts.Maybe someone can give me a bit of advice ie do I just replace the levers + release bearing and reuse the other parts, source cheaper supplier of spares,is the wear acceptable ,what do people think?
