Change front tire size???
joearizona
B2650 W/LA534 Loader & BB1260 Box Scraper, 48" Pallet forks, 72" Rake
Apr 24, 2019
53
31
Hidden Valley, Arizona
I have a B2650 with Titan trac loader 23x8.50x14 NHS tires on the front the left tire is always losing air, I have had the tire in the tire shop to many times, they are a 4 ply rated tire. I was hoping to go to a 25x8.50x14 NHS 6 ply tire, the question question will it work? or should I stay with the origenal tires & size.
Dieseldonato
Mar 15, 2022
728
438
Pa
Stay with the original size unless it's 2wd. You will mess with your 4x4 ratio. There are plenty of tire options that arnt factory in your size. 6ply is obtainable as well.
Quick search found these.
2,418
The BEST option, in my opinion, is to get the front tires foam filled.
Around here still not that expensive, and you forget about flats for the life of the tire...
Did this on both my tractors almost 20 years ago, and never regretted it.
Mrlunchbox
2023 BX2380 loader/mower. Land Pride snow pusher, Kapteyn pallet forks
Nov 21, 2020
319
141
Southern Worcester County, MA
What was your cost? Just curious. Thinking I might do that as well...
