Can't turn engine after new bearings?
4,438
I see what I did wrong.the bearings sent was 17311-22970 .those are oversize bearings and thicker than standard ones ain't they.
The bearing in your picture is .25 mm (.010 in) UNDERSIZE.
The 17311-22970 number is for a .5mm (.020") UNDERSIZE bearing.
And that mixup will sieze the rods.
garrettohio
Kubota L2900
Sep 16, 2023
89
The bearing in your picture is .1mm (.010 in) UNDERSIZE.
The 17311-22970 number is for a .2 mm (.020") UNDERSIZE bearing.
Looked at parts book and should have ordered 17311-22310 std size ones.i stoped when couldn't turn crank so all I got to do is pop the caps and put correct ones in.didnt continue assembling rest of engine
4,438
The bearing in your picture does not look to be standard. Its .010 under size. If that's what you took out and you put standard bearings in you will have loose rods (knock) and little or no oil pressure.
4,438
Absent a micrometer and dial bore gauge plastigage is your next best friend. Flying blind is dangerous.
garrettohio
Kubota L2900
Sep 16, 2023
89
That's the new one I ordered.i ordered wrong part number.old one I took out was marked std.i thought I ordered standard when installing them.but nope that was my mistake
DanDavis
Kubota L Series Tractors
Sep 3, 2024
21
Is it the lubricant thing? If the engine is not well lubricated, it may cause parts to seize.
Flintknapper
L2350DT
May 3, 2022
1,761
2,216
Deep East Texas
You do a lot of engine rebuilds?
Haha..... :LOL:
Yeah, who would have thought that engine lubrication would be important. Surely the OP used assembly lube or at least some oil on the bearings.
Looks like the OP has already figured out he has .010" oversize bearings to accommodate a crankshaft that has been turned and polished.010" under. He just needs std. bearings.
lmichael
Kubota G2160
Apr 23, 2021
604
254
Rockford IL area
Yeah that will do it. Remembering my old dealership days. One of the other techs rebuilt his 69 Z28. Did the same thing. But he insisted "oh it's just a little tight" so he had another guy do the push start thing. It finally fired (barely) then the noises coming from it. Well let's just say, "sad" very sad
4,438
Haha..... :LOL:
Read his response again. He has .010 under bearings on a crank that has not been reground and is still standard.
Flintknapper
L2350DT
May 3, 2022
1,761
2,216
Deep East Texas
Correct.
And the proper terminology for the bearings he has IS as you state.
"Undersize" rod bearings (more material on the surface facing the crank journal). Physically it is an oversize bearing to accommodate the regrinding of the crank.
Under and Oversize designations simply refer to which side of the bearing the extra material is on. Both are literally 'oversize' physically.
Of course the OP needs neither (assuming his crank journals and rod ends are OK) and just needs to go back with standard bearings.
4,438
Correct.
If you spin a bearing or beat the big end of a rod out you do not fit "oversize" bearings. You cut the caps and hone the bore back to stock size.
If you spin a rod or main bearing and ruin a crankshaft journal you regrind the crankshaft and fit an undersize bearing.
For a machinist oversize and undersize always refers to bearing diameter not wall thickness.
