I put new pistons and rings and connecting rod bearings.i ordered standard bearings but don't think there right.now won't turn.
I see what I did wrong.the bearings sent was 17311-22970 .those are oversize bearings and thicker than standard ones ain't they.Did you/can you plastigauge?
The bearing in your picture is .25 mm (.010 in) UNDERSIZE.I see what I did wrong.the bearings sent was 17311-22970 .those are oversize bearings and thicker than standard ones ain't they.
Looked at parts book and should have ordered 17311-22310 std size ones.i stoped when couldn't turn crank so all I got to do is pop the caps and put correct ones in.didnt continue assembling rest of engineThe bearing in your picture is .1mm (.010 in) UNDERSIZE.
The 17311-22970 number is for a .2 mm (.020") UNDERSIZE bearing.
And that mixup will sieze the rods.
The bearing in your picture does not look to be standard. Its .010 under size. If that's what you took out and you put standard bearings in you will have loose rods (knock) and little or no oil pressure.Looked at parts book and should have ordered 17311-22310 std size ones.i stoped when couldn't turn crank so all I got to do is pop the caps and put correct ones in.didnt continue assembling rest of engine
Absent a micrometer and dial bore gauge plastigage is your next best friend. Flying blind is dangerous.Looked at parts book and should have ordered 17311-22310 std size ones.i stoped when couldn't turn crank so all I got to do is pop the caps and put correct ones in.didnt continue assembling rest of engine
That's the new one I ordered.i ordered wrong part number.old one I took out was marked std.i thought I ordered standard when installing them.but nope that was my mistakeThe bearing in your picture does not look to be standard. Its .010 under size. If that's what you took out and you put standard bearings in you will have loose rods (knock) and little or no oil pressure.
You do a lot of engine rebuilds?Is it the lubricant thing? If the engine is not well lubricated, it may cause parts to seize.
Haha.....You do a lot of engine rebuilds?
Read his response again. He has .010 under bearings on a crank that has not been reground and is still standard.Haha.....
Yeah, who would have thought that engine lubrication would be important. Surely the OP used assembly lube or at least some oil on the bearings.
Looks like the OP has already figured out he has .010" oversize bearings to accommodate a crankshaft that has been turned and polished.010" under. He just needs std. bearings.
Correct.Read his response again. He has .010 under bearings on a crank that has not been reground and is still standard.
If you spin a bearing or beat the big end of a rod out you do not fit "oversize" bearings. You cut the caps and hone the bore back to stock size.Correct.
And the proper terminology for the bearings he has IS as you state.
"Undersize" rod bearings (more material on the surface facing the crank journal). Physically it is an oversize bearing to accommodate the regrinding of the crank.
Under and Oversize designations simply refer to which side of the bearing the extra material is on. Both are literally 'oversize' physically.
Of course the OP needs neither (assuming his crank journals and rod ends are OK) and just needs to go back with standard bearings.
