I have a nearly new BX1880 with 24 hours on it - mostly mild residential use (mowing the lawn/grading driveway).
Today when I went to fire it up, it struggled with a larger than normal puff of smoke and the hydraulics on the loader were jumping/stuttering - so i wondered if there was a loss of fluid somewhere.
Upon further inspection, the rear axle seal seems to have become unseated there was a puddle where it was parked. Is the fluid in that axle is shared through the rest of the hydraulic system?
The seal snapped right back in and there was a slight nick in the bottom, so I am wondering if I didn't just get a log or rock caught in there at exactly the perfect spot to push the seal back out (not a very robust design if that is what happened).
Should there be any harm to snapping this back in and just topping off with more fluid, or should I send it back to the dealer for an inspection to see if there was an issue with the seal or rear end? From what I could find, the seals look like it just pressed in.
If I add more fluid, what should I be using for this tractor and just to confirm, it goes in right in back where the yellow dip stick is, right?
