BX24 HST Leak?
1,698
Where is it leaking from? What does the dipstick say?
He has two videos linked (see the orange words).
It is overfull, leaking under the “middle” of the tractor.
I suggest he gets the level at least down to the max fill line and verify the vent is open. Then try to clean it with something that will remove the leaking oil. Then see if it is still leaking.
Add the UV dye and see where it is leaking from if you want to try that, but it seemed pretty obfuscated by the tractor wiring and the floor board.
Mountainman
L2501, B7100, B2710 B21, B1750, B2400, B7200
Jul 10, 2022
359
134
Attalla Alabama
mossycreekoutdoors.com
Thank you. I didn't realize the orange words were links. Good to know
8,179
It's probably leaking out the vents because you overfilled it.
And please quit calling it an HST service, it's not.
All you did was change hydraulic filter and fluid!
Very common for this vent line to go bad and leak.
Ngiovan
BX24, ZD326S
Dec 20, 2024
42
17
Pennsylvania
Finally got around to getting it back to level. Still has a leak, but has noticeably slowed.
Mentioned it to my local dealer when I stopped in for some mower parts and they printed the same picture that @North Idaho Wolfman posted and said it was likely the culprit.
I’ll look to address it the next rainy weekend. In the meantime, is there any concern with continuing to run the machine?
Finally getting some good weather and I’d hate to miss some hours in seat.
8,179
If the leak is really low, it could allow dirt or water to get into the hydraulic system, so I wouldn't wait to long to repair it.
8,179
Spray it all off with brake parts cleaner, then you should be able to pinpoint the leak better.
