bx2380 chains?
BillSz
20
Northfield, Mn
I am a new owner of a 2380 and today was the first time I got to try it plowing snow. The was only 2"-3" on the driveway but I had minimal traction. I am using the plow attached to the FEL with unweighted turf tires. I do have a ballast box with about 300 lbs. of weight on the back. I have been using 4WD in low gear.
I should mention that before today we had rain/warmer weather (very unusual for Mn) and my gravel driveway has ice under the snow.
My questions are:
1. Should I take the weight off the back since I am not lifting anything with the bucket at present? Would that help with front end traction?
2. Are chains, both front and rear the answer?
For those of you with experience, what would you recommend to improve traction/snow moving capability?
Thanks in advance,
Bill
6,216
Bill - chains, absolutely! Leave ballast box on.
I suggest 2-link ladder chains. I put them on without spacers, but many guys have added spacers for more room. Kept tight and “cheating” to the outside, I haven’t had any issues in 5 years.
Thus far, I have them on rear only. I would not be able to function without them.
6,216
Bill - I should add I'm just pushing a blower.
I certainly couldn't push a plow without chains.
SDT
multiple and various
Apr 15, 2018
3,296
1,070
SE, IN
My questions are:
Thanks in advance,
Bill
Chains are BY FAR the best way to increase snow traction. Rears for traction, fronts for steering.
Keep the ballast box on.
Since you are plowing on gravel, you have the option of using aggressive chains that are damaging to concrete and asphalt. Go to tirechains.com and learn about the options. You may want to try the relatively new "euro" style with studs. Expensive but effective. Use both F & R.
Adjust the skid shoes to avoid digging up the gravel and plow with the FEL in float mode.
For significant snow, you may need more rear ballast to counterweigh the FEL mounted plow. I use a ballast box weighing about 400 Lbs. and loaded rear tires (dealer mistake) on my B3350 with FEL mounted plow.
SDT
WAS BANNED FOR NSFW PICS
5,143
I have been plowing or snow blowing for over 10 years with loaded turf tires on a asphalt driveway about 1600', without chains. I have always used my weight box with about 650# of lead in it, and never have had a problem. I have chains, but have never installed them. I also have an incline, and can always climb it, albeit with some difficulty if using the blade. Snow blower never has a problem. This will be the first year that I will be plowing/blowing without my weight box, since my 3 point hitch isn't working. I am hoping that the backhoe will be enough weight to do the job. I am not going to fault anyone for using chains, because that is a personal decision, just giving my experience with my BX22.
Blue2Orange
BX2380
Apr 3, 2025
Bayview Township
Downsizing from a class 2 NH to the BX2380. Survived 25 winters using a rear mounted 60" Loftness snowblower and no chains. Loader and heavy duty bucket stayed attach. Like the combo for dealing with our Lake Effect dumps.
The BX is a significantly lighter tractor. Tires chosen are the R4 industrials. Considering chains for next winter. Driveway is ~900 foot surfaced with what we call "blue gravel". Average grade is only ~4%, but the steeper sections exceed 9%. Will be using just the std 48" bucket and SB1051 3 point mounted snowblower.
The BX has such small front wheels that I'm guessing not a significant cost to add couple more chains for improved traction and directional control Opinions? Waste of $$s
Minimal clearance between the plates protecting the operating lever hardware and rear tires. Willing to give up the additional traction of larger chains. Do they make chains similar to what you see on some passenger vehicles? The ones that look more like just coils vs. links. If so, any user feedback?
6,216
Some use front chains. Can be a challenge to put them on the small front tires on a BX. They can hit the front axle if not careful.
I’d put wheel spacers on the rears of your BX2380 and put regular ladder chains on. Spacers will give you some room.
Spacers are ill-advised and don’t do anything on the front wheels.
Blue2Orange
BX2380
Apr 3, 2025
Bayview Township
Probably just keep it simple. Like what you noted in an earlier post.
Thanks everyone.
