Bx2370 won't start
bluelight16
BX2370
Sep 18, 2022
I just changed oil trans fluid and filters along with fuel filters, went to start and it would not go I have a cartridge fuel filter and a jar type (not sure what you call them) and I changed both, I have to believe I got air in the lines, I filled the tank with fuel tried the manual method of holding the key for 30 seconds then try to start but did not go, any suggestions I have had it for over 10 years never had a problem thanks
2,686
You ADDED an aftermarket fuel filter?
Do the 30 seconds AGAIN - and let it eat(hold it longer - you will not hurt anything) , you should hear the fuel pump buzz and whatnot, once the fuel IS FLOWING the pitch will change - continue and then try to start.
Picture of fuel filter would help
5,469
According to the op manual for my BX23S, sister to the BX2370...
turn key on for 30 seconds
turn key OFF for 30 seconds
turn key to preheat 5-10 ( I always do 5 'steamboats, year round )
turn key to start
2,686
turn key to start
He has enough air - that 30 needs a wee bit more :ROFLMAO:
WI_Hedgehog
Apr 24, 2024
537
639
Milwaukee, Wisconsin, U.S.A.
@bluelight16 : Pictures are worth 1,000 words. If you added an aftermarket filter I would imagine you want to put the output hose into a jar and prime the fuel system until fuel without trapped air runs out.
I'm not a tractor expert so someone might want to elaborate on this.
bluelight16
BX2370
Sep 18, 2022
Thanks fo reveryones comments after alot of trying to get my BX to start I ended up finding a wire to the fuel pump was broke unfortunately it was broke at the sealed connector so i had to take the pump off and do some rewiring let me tell you that being 78 and a little on the heavey side it was no easy job crawling around under the tractor but everything is working now so untill the next problem, thanks again.
