BX2200
Dtillotson
BX2200
Feb 17, 2024
Joshua, TX
Starts and runs great for 15-20 minutes then loses all power. Replace fuel filter near engine but not change. The fuel filter is full. This may be the place to look for suggestions
Edke6bnl
B7800 Kubota, case 1840 Skidsteer Ford 3500
Mar 31, 2022
195
Agua Dulce, California
I have herd others have problem with algae in the fuel or some other grud that floats around and randomly will plug the exit of the fuel in the tank. also might want to check the vent hole in the fuel cap
dlsmith
BX2230, LA211
Nov 15, 2018
1,210
744
Goshen, IN
You may need to change the filter that is back between the tank and the fuel pump.
3,198
Loosen the fuel tank cap and see if that fixes it…. and that will prove if it’s the cap vent.
2,478
I had a similar problem with my BX2200. I can't remember exactly what the symptoms were, but fuel starvation came to mind at the time.
I bought both fuel filters, and changed the one near the fuel pump. Cut it open and it was terribly dirty! Of course, first change in about 18 years. (red face here). That was a couple years ago. Still have not got around to changing the easy one next to the engine.
Add my vote to changing the filter near the fuel pump, which is the first filter in line and likely to be the culprit.
GoeHorn's suggestion is also important to try. Many threads here on BX tractors where blocked fuel tank venting caused an issue like you are having.
edit: Another somewhat common issue is something floating around at the bottom of the fuel tank, which blocks the fuel exit point intermittently and causes symptoms like you are describing...
