J jfr3 New member Equipment Bx1500 Mar 27, 2023 3 0 1 Northern Wisconsin Apr 11, 2025 #1 Anyone running a BX1500 with a flail mower? I was told I could run a 42" brush hog with no issues, but the flail would be better suited for end result. Any help is appreciated.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 32,587 8,191 113 Sandpoint, ID Apr 11, 2025 #2 I can't find a flail that will work with only 10HP? Smallest I can find is 16hp minimum. Hurricane H40-S flail mowers Hurricane H40-S flail mowers, flail shredders, choppers, municipal mowing, tractor mounted, three point hitch, quick hitch compatible befco.com
J jfr3 New member Equipment Bx1500 Mar 27, 2023 3 0 1 Northern Wisconsin Apr 11, 2025 #3 North Idaho Wolfman said: I can't find a flail that will work with only 10HP? Smallest I can find is 16hp minimum. Hurricane H40-S flail mowers Hurricane H40-S flail mowers, flail shredders, choppers, municipal mowing, tractor mounted, three point hitch, quick hitch compatible befco.com Click to expand... Is the 16 hp at the rear PTO? The tractor is 15hp.
J jfr3 New member Equipment Bx1500 Mar 27, 2023 3 0 1 Northern Wisconsin Apr 11, 2025 #4 I have been using a Landpride 51" 3pt snowblower with no issues.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 32,587 8,191 113 Sandpoint, ID Apr 11, 2025 #5 jfr3 said: Is the 16 hp at the rear PTO? The tractor is 15hp. Click to expand... You only have 10.5 HP at the PTO.
