bx wheels dont interchange
ipz2222
L235, bx2670
May 30, 2009
1,927
31
38
chickamauga ga usa
Sold my bx2230 several years ago. Had a full set of tires and wheels with turfs and r1's. Sold the bx with the turfs on it and kept the r1's. Bought a new bx 2670 and ordered the industrial tires with it. Noticed the front wheels looked different and cked the size. They were 10 inch and the wheels from the 2230 were 8 inch. Outside dimension was the same Just chalked it up to being the industrial tires. Last week , tore a hole in the side of one of the front tires. Closest one was 2 days away . NO problem, I'll just put the 2 spare ag tires and wheels on. Surprise!! The wheels hit the housing that holds the bevel gears. Somewhere along the way, Kubota changed the housing size. The solution was a set of spacers . Cheaper and a whole lot faster than selling the ones that don't fix and buying new ones.
5,215
Careful doing that, moving the wheels out even an inch changes the center line out and increases the load on the bearings drastically. :(
Grouse Feathers
Feb 16, 2015
1,022
Lovells, Mi
This is especially true on an axle as short as the front axle on a BX. Spacers on the rear axle have a longer moment arm so the load on the bearing doesn't increase much.
2,240
Is there an offset in the wheel? If so, can you flip 'em for more clearance?
chucky79
BX25D, B7100 Restoration project with a B219 loader and B670 backhoe
May 16, 2014
91
Ashland, KY
So my 2" Brotek rear spacers just arrived. Is there some caution that needs to be observed regarding the bearings?
Wondered that myself. Think I read in the BX manual not to use spacers but dont know why?
