BX Debris forks
Bri-Guy-GA
Kubota BX1880
Sep 10, 2020
182
117
Villa Rica, GA
Looks for debris forks so I can pick up the wet hay and manure the horses drop around the hay feeder. Tried with the bucket, but its just too wet and sticky to really pick up. I figured forks would work better. Anybody know of some for the smaller BX bucket? I'm not opposed to the clamp on ones, but the removal after would just be nasty.
2,891
I had some forks built by this company:
Kind of a pain to get them , as the first set were lost or stolen in shipping, but they have become my favorite implement.
They will custom build to suit.
I would think a quick zap with a hose or maybe a pressure washer would work before dismounting.
Some threads:
Sidekick
Jul 29, 2023
861
1,023
N.Y,
2,891
Something to keep in mind when buying these clamp-on forks.....
My neighbor borrowed mine & liked them so much he that bought some for himself, but he bought some no-name ones off e-boy.
They fit, but the T-handle clamp screws were too close to the inside wall of the bucket, and he had to shorten the "T" handles to clear.
That meant he couldn't get them real tight by hand, and they shifted while using them.
Now he uses a short pipe or a hammer to get them tight.
Not a deal breaker, but something to think about.
I replaced the T-handle clamps on mine with short hex head bolts, because the "T"s stuck up about 4 1/2" from the forks, blocking stuff on the forks from sliding back into the bucket.
The bolts only stick up about 3/4", and I already carry an open end wrench that fits another implement with me anyway, so it works well for me.
Sidekick
Jul 29, 2023
861
1,023
N.Y,
If they loosen off..... can you add a 'locknut or jamnut' to the bolts ?
Mine never loosened. They had a sliding handle and could be tightened right near the edge of my bucket. The cheaper ones are thinner metal that allows flex causing loosening. They locked onto the back of the cutting edge so there was no way to pull them off.
2,891
Mine never loosened either, but my neighbor's did because he had tto cut so much of the "T" handle off he could not get any leverage.
I tighten my shorter hex head bolts with a CTI Cryo Pump wrench, like the one below,
In other words, it holds in place without a huge, long, high leverage wrench.
Bri-Guy-GA
Kubota BX1880
Sep 10, 2020
182
117
Villa Rica, GA
I bought a pair off of Amazon and they worked pretty good in picking up the wet poopy hay. Loss of traction was the biggest issue, so may need to go from Turfs to R14 in the rear. The forks are about 80lb so definitely stout and once bolted down tight stayed in place.
