BX 54" MMM (mid mount mower) with only 25 hrs!
tcrote5516
BX1860, FEL, 50" Front Blower, Heated Cab, 6' blade, 3pt carry all, 3pt hitch
Sep 2, 2014
482
Southern New Hampshire
I'm selling the MMM that came with my BX. I bought the BX because of my yard being so tricky I needed 4wd to get up and down. Once I got the BX I ended up regrading the whole yard using the FEL and backblade and now can mow it with a Zero Turn!
The deck has been stored in my garage and only has 25 hrs on it (most likely closer to 15 hrs but since I'm not 100% sure I'm shooting high). I did properly maintain it and greased all fittings in the spring/fall. The deck is less than 2 years old and is in fantastic condition (minus the usual scrapes on the left side). Comes complete with both belt covers, PTO shaft, ujoint and both front mounting brackets.
I will strap it down to a pallet if you arrange all other shipping needs.
$1200
Edit: Model # RCK54-23BX
