Grouse Feathers
The BX operating manual does not give a good explanation of how the 3 point ¼ inch function works. To use the ¼ inch function you need to pull the three point lever towards the seat and then move it in the up or down direction and you will contact a stop at about ½ of the full lever travel (picture 1 if you look close at the picture the down stop is just to the left of the black 3 point knob). If you hold it against the stop the 3 point will go up or down slowly. If you just bump the stop and release the lever you bump the 3 point in the up or down direction about ¼ inch.
The ¼ inch function on my 3 point hitch never seemed to work and then I noticed an adjustment for the stops under the fender. In the up direction the 3 point would not move when the lever was against the ¼ inch stop. In the down direction it would move too fast or when bumped would move about 1 inch. The adjustments for the stops are between the fender and wheel (picture 2). In the picture you can see the up direction stop, the down direction is behind the shift lever. I adjusted mine to give me about ¼ inch of movement at the implement, and this is probably closer to 1/8 inch at the lift arm. I am sure some of you are aware of this adjustment, but for the others you might find this valuable.
