BX 3-point height indicator
BXHoosier
BX24
Jan 21, 2018
457
517
Indiana
In the thread about changing the BX 3-point to position control, someone mentioned adding an indicator instead. I decided to add a pointer in the slot intended for the optional rear remotes. Today, I got the pointer made and mounted. The pointer is attached to a delrin plastic piece that pivots on an aluminum post. It will be moved by a sleeved cable (choke cable) hooked to the 3-point rocker shaft arm.
BXHoosier
BX24
Jan 21, 2018
457
517
Indiana
The indicator works. The cable attaches to the lift arm with a plate held by a U-bolt. I made a cable clamp that is mounted to the backhoe subframe using an existing oval hole and a couple fender washers.
BXHoosier
BX24
Jan 21, 2018
457
517
Indiana
Thanks guys. I’m going to shorten the pointer and add some graduations and possibly an adjustable reference marker.
