My BX 2200 power steering line leaking between dash and front. Lines are wrapped in cloth cover so cant tell which has failed. I plan to replace both to avoid future frustration. It is very difficult to get a wrench on fittings on hydraulic cylinder on front axle. Ended up loosening the bolts holding cylinder in place (3 each end) to get enough play to get a wrench on the fittings. I can tell it will be difficult to reinstall new lines since it was tough getting originals off. Is there a trick to this? I was tempted to drop the front axle for easier access but wasn't sure how tough it would be to get that re-aligned.
Thanks in advance for your help!
Bob
Bob
