I've decided I've had enough of my 1942 2N. I have 5 acres with a half dozen scattered trees, a small "stand" of 10-12 trees along a "creek" that only flows when it rains hard, a septic pond and an "ornamental" pond about 2-3 times the size of the septic pond. The 2N was fine for pulling the brush hog when all I had was empty pasture. It pulled a small plow once in a blue moon for my wife's 25'x25' vegetable garden and once a year or so ran a post hole digger. Well, that's when the 2N would start that is. It always seems like I have a problem with it just when I want to use it. I'm tired of spending more time next to it than on it. I want something that "just works."
2 years ago we fenced the property into 3 separate pastures, put up a 36x36 monitor barn (with hay loft) and added 3 horses and a dozen chickens to the mix. The house sits 50' from the road so my gravel driveway is very short at 80' feet or so to the rear of the house. It needs some maintenance from time to time, but not much. I can find uses for the FEL. I've wished I had one on quite a few occasions when getting a load of dirt or gravel out of the back of my F150.
I think I could probably get by with a large B but the L seems so much stouter. The 3800 adds $1,500 to the cost and I'm just not sure if the L3200 isn't already meeting the "figure out the size you need and then go one bigger" maxum.
So I'd like comments on whether for my needs I'd really ever use the extra 5 horses. I don't plan on ever buying another property or another tractor.
I'm considering getting a rear blade, box blade, 5' brush cutter. Any recommendations on specific Land Pride models would also be welcome. I can get a good deal on any of the Land Pride stuff I buy with the tractor.
