Hey all - thanks for taking the time. I am a very new tractor owner and I know very little about hydraulics and tractors in general. I bought a used b7100 - it was not leaking at all when I purchased it. After it arrived at my place, I noticed it starting to leak hydraulic fluid out of a fitting. Now it basically pours hydraulic fluid out of this fitting. I made sure that it is tight and it still leaks. Please see attached picture - the leak comes from the green arrow location which is between a female hex fitting and a longer hexagonal piece of metal that is perpendicular to the hose coming in. If I unthread the hose from the female fitting, the female fitting spins freely in place meaning it is not threaded to the hexagonal piece of metal. I am assuming as I thread and tighten the hose into the female fitting, it should tighten in place.
Anyways, I am almost certain I need to replace something here. Can anyone provide any pointers on how I can figure out what I need to replace and where I can buy those components? Thanks again
